Z-Axis failing calibration
blahblahblah4444
(@blahblahblah4444)
Miembro
What causes the failure? I have re-centered the vertical rods three times. I have re-seated the hot end three times. I cannot get past the z-axis calibration.
Every time the z-axis fails, it is after it goes down to touch the bed. Moves slightly up, then down. Then moves to the top position to say it has failed.
Any help would be greatly appreciated.
Respondido : 22/12/2024 4:36 am
Lil_Lex
(@lil_lex)
Miembro
RE: Z-Axis failing calibration
Don’t know if you were able to fix it, but was having same issue.
i was able to fix the issue by hitting reset button
Respondido : 06/01/2025 12:19 am
Csaba Molnár
(@csaba-molnar)
Miembro
The z-axis test fails. The nozzle hits the table hard. I can't solve the problem.
Respondido : 15/01/2025 3:30 pm
dotmap3d
(@dotmap3d)
I just posted what worked for me today.  I moved my z axis to zero position (where nozzle was not touching the bed), shut off power, and manually moved Z so nozzle touched the bed, then powered up, and re-ran z axis test - success.
https://forum.prusa3d.com/forum/postid/733089/
Respondido : 19/01/2025 3:56 am
JimM
 JimM
(@jimm)
Miembro
I''m also having this problem, among other things. I can't get the mmu3 to load filaments. Its stuck on filament 2 and I want to print on filament 1. I also can't find the chat window to get some advise.
Respondido : 21/03/2025 6:56 pm
JimM
 JimM
(@jimm)
Miembro
I also am having a problem with the MMu3. It is stuck saying that it is detecting a filament too soon, yet there is no filament being loaded.
Respondido : 21/03/2025 7:05 pm
