Y-Axis calibration is failing after several good prints
sassch
(@sassch)
Hello,
I upgraded my MK4 to MK4S. It worked fine for several prints, however, the last few prints fails due to shifts of the y-axis. Therefore, I did a new calibration, however, it fails now. I checked the tension of the belt and it was to tight. Therefore, I decreased the tension. Now, it is fine. However, the calibration of the Y-Axis still fails. Any ideas?
Best regards
Veröffentlicht : 26/12/2024 9:27 am
Brian
(@brian-12)
RE: Y-Axis calibration is failing after several good prints
Please search the forum.  There are lots of threads similar to this, although usually new builds.  Maybe something got out of position or installed incorrectly when you changed the belt tensioners.  I'd start going over your install, then of you can't find anything most y axis calibration fails are because of the bearings being or 3 of position.
Veröffentlicht : 26/12/2024 7:21 pm
The420Physicist
(@the420physicist)
Mitglied
I would start with the two bearing on the left side under the hot bed. I would guess that going back and forth they may have gotten knocked inward a little. Those bearing have to be in perfect placement. And TBH, there isn't a clear show of what is perfect in the manuals. I used a paper clip, put the end of the paperclip in the lip of the outside inset of the bearing and pushed the bearing up to the bracket. After I did that, my y-axis would pass... hard to describe without a picture.
I was kind of nervous about them getting knocked out of spec because bearing smack the rod brackets sometimes. Especially since the bearings aren't that tight or it bind up.. not terribly happy with precision of that part.
Hope this help you some.
Veröffentlicht : 30/12/2024 6:48 pm
sassch
(@sassch)
Happy new year.
I finally had time to check the Y axis again.
I checked the bearings. I've ensured that the two bearings are positioned as near as possible to the center without touching the edges and that the singe bearing is centered, as described in the assembly guide for the MK4S. (I only upgraded my MK4 to MK4S)
I checked the tension of the belt several times using the belt tuner. The calibration still fails.
In the rear position the rear bearing does not touch anything. However, the front bearing touches the rod holder in the front position.
Veröffentlicht : 05/01/2025 6:02 pm
is the y axis
belt tensioner, the correct way round?
Veröffentlicht : 05/01/2025 8:27 pm
sassch
(@sassch)
Yes, it is.
As I mentioned before, it worked for several prints. I did the calibration after the upgrade and it was successful. After 2 or 3 days of printing, it started printing with a incorrect Y axis. Therefore, I did the calibration again and it fails everytime now.
Veröffentlicht : 05/01/2025 10:58 pm
sassch
(@sassch)
Any ideas what else I can check?
The calibration fails when it is moved to the front.
Veröffentlicht : 07/01/2025 10:45 pm
chmax
(@chmax)
pulling at straws here but did you check the rod holder's screws? I my mk4s (and the mk4 before the upgrade) all screws would shake themselves loose by at least a quarter turn after a couple of weeks printing.
I now regularly go through all and retighten...
Veröffentlicht : 14/01/2025 9:52 am
sassch
(@sassch)
Yes. I checked all screws. But many thanks for the hint.
Veröffentlicht : 21/01/2025 12:31 pm
PlumpCat
(@plumpcat)
Mitglied
I think the bearings are actually supposed to be positioned closer to the center rather than close to the edges. I continually failed y axis right out the box until I did this.
Chapter 7 Section 17 of the mk4s build guide. Check the comments there too.
Veröffentlicht : 22/01/2025 9:20 pm
sassch
(@sassch)
Posted by: @plumpcat
I've already tried that before. But I will try it again. Many thanks.
Is there a way to get logs from the printer?
At least I expect that such failures are logged with the reason why it fails.
cheers
Diese r Beitrag wurde geändert Vor 1 year von sassch
Veröffentlicht : 22/02/2025 11:46 am
Steven Smith
(@steven-smith-3)
Mitglied
Posted by: @sassch
Hello,
Best regards edurev infinity free mod apk by alphamodi.com
It sounds like your Y-axis might still have an issue with misalignment or obstruction. Check for loose pulleys, ensure smooth rail movement, and inspect motor connections. Let me know if that helps!
Veröffentlicht : 12/03/2025 6:23 pm
sassch
(@sassch)
Apologize for the late reply.
No I checked everything multiple times. No loose pulleys, the rail movement is smooth and the motor connections are also fine.
It would be very great if the software tells what exactly the error is. Then it would be much easier to fix it. I spent several hours to find the reason and I still do not have a working printer. That's quite annoying.
Veröffentlicht : 24/08/2025 2:11 pm
sassch
(@sassch)
Ok calibration worked now.
It worked fine before the upgrade. After the upgrade it worked for several prints as well.
Then it started to have print errors. Therefore, I tried to calibrate it again. I checked everything.
Today I put a cable tie on the one side that the movement of the y axis stops earlier and it worked afterwards.
That is a strange behavior IMHO.
Many thanks to all of you.
Veröffentlicht : 24/08/2025 2:47 pm
