Variable Layer height issue
tsetse fly
(@tsetse-fly)
First time I used the variable layer height and wondering what caused this issue.  Looks like it printed right up the point where it was going to change layer heights and then went to an extruder blob
There is a start and stop for the layer heights and I had the first stop at height and the next start at height as the same number (shown in image).  Would that cause this ?
Seems like a good option for a warning in slicer.  What if there is a gap between first stop height and next start height ?  Curious how these heights are processed if someone knows.  What should be entered for the 2nd start height (what increment) ?
Thanks for any insight
MK4S
fw 6.2.3
Postato : 31/03/2025 2:41 pm
RE: Variable Layer height issue
I'm pretty sure this has nothing to do with your use of Height Range Modifiers (Variable Layer Height is a different function in Prusalicer, not what you were doing). There's certainly absolutely nothing wrong with the end height of modifier 1 being identical to the start height of modifier 2. If you look at the preview and switch to height, you'll see that it works as you would expect. If the crash happened at that height, I suspect it's probably because you chose that particular height due to a specific feature in the model, and that the crash is more related to that feature.
Postato : 31/03/2025 11:06 pm
