Rapid decline in print quality
Flok
 Flok
(@flok)
Mitglied
I have build my MK4s and not being the biggest techie was very happy it worked just fine on the first prints. But that totally detitorated.
That was the quality I got. But two days later  the same print looks like that:
I tried a Benchy . It was a mess (the earlyer prints were ok).
Same filament. I reset the printer. Did all calibrations again. I have no idea whats the problem...
Veröffentlicht : 24/10/2025 3:19 pm
mnentwig
(@mnentwig)
moisture. Try a fresh spool out of the bag and ideally it should be good as new.
Look for ways to keep it dry (sealed bag, desiccant, oven drying). It's a very common problem with PLA. The process is reversible so you can dry it, check the forum.
Veröffentlicht : 24/10/2025 5:29 pm
mnentwig
(@mnentwig)
RE: Rapid decline in print quality
I had ChatGPT look it up (below is AI response, looks meaningful though):
Yes — that print strongly looks like a moisture problem in the PLA filament.
Here’s what points to it:
🔍 Visual clues
The surface is rough, bubbly, and uneven, almost like it was foamed.
Layers don’t bond cleanly and have stringy, blobby extrusions instead of smooth roads.
The print is matte and irregular, not the usual glossy look of dry PLA.
Those are classic symptoms of steam bubbles forming as water in the filament vaporizes in the hotend, causing micro-explosions and inconsistent flow.
🔥 Quick confirmation
You can check in a few ways:
Listen while printing — moist filament pops and hisses as the moisture boils.
Check extrusion: if it spits or smokes slightly, that’s moisture.
Try drying a few meters of filament for 4 h at 45–50 °C and reprint — if it looks dramatically better, moisture was the cause.
💧 Typical moisture sources for PLA
Absorbed humidity (PLA is mildly hygroscopic).
Storage in open air for days or weeks.
Long periods in a cold, humid basement.
🧑‍🔬 Drying guidelines FilamentTempDurationNotesPLA45–50 °C4–6 hIn food dehydrator, filament dryer, or oven with thermometerPETG65–70 °C6 hMore heat-tolerantABS80 °C4 hDon’t exceed 85 °C to avoid softening the spool 🧰 Prevention
Store filament in a sealed box with silica gel or a vacuum bag.
Keep the spool in a dry box during printing if your room is humid.
Veröffentlicht : 24/10/2025 5:33 pm
Even the first picture is showing signs of moisture - dry the filament.
But I suspect the later prints are exhibiting a second, fairly common, newbie problem 'though the moisture is masking it; so dry the filament, print again, and if the print is still a little off come back and we'll take another look.
Veröffentlicht : 24/10/2025 6:53 pm
Flok
 Flok
(@flok)
Mitglied
Hey. Unfortuenately a change to New filament did not do the trick. What might bemüht that other newbie problem?
Veröffentlicht : 24/10/2025 7:35 pm
Posted by: @flok
The other filament you changed to, was it dry? How is it stored?
Veröffentlicht : 25/10/2025 4:25 am
Flok
 Flok
(@flok)
Mitglied
Well, it was a prusament straight out the box (still sealed).
Veröffentlicht : 25/10/2025 8:41 am
New <> dry.
Typically the amount of drying needed varies with the season and with individual air treatment.  Some filaments always need drying but PLA can often be used without during summer (air conditioning) and winter (central heating) 'though it usually needs drying during the change of seasons.  Machines and filaments used in outbuildings almost always need driers.
Even new Prusament may need drying; it was packed dry but the dessicant can only keep it dry for a few weeks.
Veröffentlicht : 25/10/2025 10:59 am
MileHigh3Der
(@milehigh3der)
Drying is the IT equivalent of “reboot it”; yes it solves a lot of problems.  That looks like fuzzy skin setting! Not saying it is.  I’ve had weird prints like that before.  Sometimes I think that the slicer or the printer firmware gets a ‘hitch’ in it.
PLA isn’t that water sensitive, and a new Prusa spool should give better than that.
Try another model, try another printer (who has just one nowadays 🙂 ), reflash/update the printer, and reinstall PRusaslicer.
Good luck.
Veröffentlicht : 25/10/2025 2:56 pm
darkmattermaker
(@darkmattermaker)
Looks like a (partial) nozzle clog to me.
Veröffentlicht : 26/10/2025 2:45 am
IdoA
 IdoA
(@idoa)
Mitglied
I'm experiencing something similar.
A very noticeable decline in quality of print, no matter the material. the printer seems to move too fast for the material flowrate in my case. slower prints seem to look a little better, but it's still not great.
Veröffentlicht : 18/11/2025 9:25 pm
mnentwig
(@mnentwig)
Posted by: @idoa
Do you hear the extruder clicking? That would be expected to happen when the filament doesn't move as rapidly as intended.
BTW, as pointed out by Diem and others frequently: Even taken from a sealed vacuum bag, the material is not necessarily as dry as it should be. Having finally bought a drier, this is getting obvious...
Veröffentlicht : 18/11/2025 10:51 pm
cboshdave
(@cboshdave)
Mitglied
Just a weird thought.  I recently had similar problems.  The print would start fine and then go a little wonky. It was like I was only getting a portion of the filament to feed out.  I found that in my assembly, I missed the "Heatsink spacer".  It was causing all sorts of odd problems. I made a lot of changes, but this was the major one.  The following link shows the step in the nextruder assembly.
https://help.prusa3d.com/guide/5-nextruder-assembly_707767#714548
Veröffentlicht : 19/12/2025 7:11 pm
cboshdave
(@cboshdave)
Mitglied
Just in case the website is not accurate. Here is the specific picture.
Veröffentlicht : 19/12/2025 7:39 pm
