RE: Print quality with PCCF
This looks like you did not dry the filament. If this is anything like Prusament PC-CF, this should print flawlessly, if it is dry enough.
Veröffentlicht : 06/12/2024 2:07 pm
It is a common assumption by many people that new/fresh out of the sealed bag equals dry enough for printing. This is not true for filaments like PETG, TPU, PC, ASA and PA. To ensure repeatable results it is generally best to dry a new spool first at the recommended settings for temp and duration for that filament type. Some types like PA (Nylon) even require to print directly from the dryer, because they are very hygroscopic. And if you see stringing on your prints, first dry the filament before you begin changing any slicer settings.
Veröffentlicht : 07/12/2024 8:21 am
