Power keeps cycling and screen won't turn on
lpow100
(@lpow100)
I just finished building a MK4S and just finished, I turn it on then I hear the fan for a bit and the LCD doesn't turn on. I've tried unplugging and re-plugging the LCD's ribbon cable but nothing works
Napsal : 25/02/2025 9:28 pm
Contact Prusa Support via Chat, you will need your printer's serial number; they will talk you through a check and fix process.
Napsal : 26/02/2025 10:38 am
lpow100
(@lpow100)
RE: Power keeps cycling and screen won't turn on
Turns out, I just had to reread, redo, and look extremely carefully. Thanks a lot though!
Napsal : 27/02/2025 12:33 am
