[Resuelto] PETG filament stuck
nurp
 nurp
(@nurp)
Miembro
PETG filament stuck
I made my first print with PLA without issues. Now I try PETG. This is a second hand printer, so not sure about it's history.
I bought this Prusament PETG from Clearance:  https://www.prusa3d.com/product/prusament-petg-signal-white-1kg-clearance/
The page says temperatuer setting: 250 C.
In PrucaSlicer, I also set to "Prusament PETG".
I loaded PETG into the printer.
While printing, it stops every minute or so, saying the filament is stuck. I unloaded/loaded so many times.
Did cold pull
I noticed in the hardware settings, on the printer, that high flow was enabled. I disabled it as I have a standard .4mm nozzle. I don't know why by default it was enabled??? I had already done factory reset!
Also, why the filament PETG setting on the printer (manage filaments) is set to 230 C? Can it be the issue? Do I have to change the nozzle? Can I make a nozzle replacement tool out of PLA?
Respondido : 27/02/2026 12:11 pm
nurp
 nurp
(@nurp)
Miembro
RE: PETG filament stuck
changed the nozzle to ObXidian - 0.4 mm and it's printing fine now.
Respondido : 27/02/2026 5:27 pm
