MK4S Print with Organic Supports produces Steps instead of smooth surface
JohnTheGuy
(@johntheguy)
I have only been printing for a couple months, so clearly not expert in any of this...so looking for some help from the Community.
I am attaching a Model from Fusion 360 that requires a lot of supports.  I am using the Organic supports for this print.
I am also attaching a screenshot of the slicer output and a picture of the resulting print.
Is there any way to get a smooth surface on the front part of the print instead of the many steps from front to back?
I realize that this is a very shallow angle  of the front panel such that we may be seeing the discrete steps of layer thicknesses.
I have tried rotating the model so that the front face is roughly parallel to the platter, but the step persist, just get wider so fewer of them.
I wasn't sure what I need to provide in terms of setting and the best format to include those.
Best Answer by TeamD3dp:
What you see are the layer step lines, as you suspect, which is why they get wider when you try to adjust closer to parallel.  I would take the entire model and rotate it around X or Y axis so that the layer lines are oriented completely differently.  With some modeled supports, you should be able to print this part at a 45 degree angle. See Slant3d's YouTube videos about printing boxes diagonally.
I've tested this, and it's not terribly hard to do, and results in a box that (although slower because of the overhangs) prints with well hidden layer lines.  In addition to the above, you could add a touch of fuzzy skin (as he also does in the video) to further obscure the lines.
-J
Posted : 12/03/2025 1:14 am
TeamD3dp
(@teamd3dp)
-J
Posted : 12/03/2025 12:49 pm
TeamD3dp
(@teamd3dp)
RE: MK4S Print with Organic Supports produces Steps instead of smooth surface
Posted : 12/03/2025 12:56 pm
JohnTheGuy
(@johntheguy)
Thanks very much I will give it a try.
Posted : 12/03/2025 4:57 pm
JohnTheGuy
(@johntheguy)
I simply placed the model on its side and it printed perfectly smooth on all sides.  Thanks very much.
Posted : 13/03/2025 2:12 pm
TeamD3dp
(@teamd3dp)
I'm glad to hear that you found success in reorienting it. 👍  Something to consider, which may not matter much to you, but one of the advantages of printing near a 45 deg angle is the reduction in support material, since most of the parts (in a simple box design at least) won't require support.
-J
Posted : 14/03/2025 3:04 am
