MK4S Enclosure Handles
Don Stein
(@don-stein)
Hello--I'm a newb who just finished assembling both the MK4S printer and the enclosure, with the exception of the enclosure transport handles. I had great luck printing a variety of objects in both PLA and PET G, including those handles. The problem I'm having is that the spots for the M3nS nuts is filled with filament. Does anyone have a hint for removing that to open up space for the nuts?
Thanks
Napsal : 04/03/2025 12:16 am
RE: MK4S Enclosure Handles
are you printing with support material enabled?
if yes, then try without supports enabled.
Napsal : 04/03/2025 3:59 am
1 lidem se líbí
Don Stein
(@don-stein)
Thanks Joan. I'm pretty sure supports were not enabled. The material in those openings does look like supports though.
Napsal : 04/03/2025 2:51 pm
I printed mine without supports and they worked fine!
Are you using the 'thin' nuts?
Napsal : 04/03/2025 5:15 pm
