Mk4S crashes when using the Mk4S slicer
Daniel Weitz
(@daniel-weitz-2)
When I try to print something that was sliced on using the Mk4S slicer on the upgraded Mk4s I get a 'heat crash.
When I slice it on the Mk4 Input slicer settings, it then slices fine.  Why will it not print on my 4S  using a Prusa sliced 4S setting?
Postato : 07/12/2024 4:27 pm
Daniel Weitz
(@daniel-weitz-2)
RE: Mk4S crashes when using the Mk4S slicer
Problem solved when I put on the "optional"  silicone sleeve.
Postato : 07/12/2024 6:39 pm
TeamD3dp
(@teamd3dp)
When you added the silicone sock, did you also toggle the setting in the printer interface to let it know that you were adding the sock?  If not, the problem was likely that the printer was set for having the sock installed when it wasn't.  Adding the sock aligned the settings with reality.  If this is the case, you can likely remove the sock if you like, as long as you toggle the firmware setting to let it know you are not using the sock.
-J
Postato : 14/12/2024 2:56 pm
