Missing a part? or is the manual out of date?
Jim Springer
(@jim-springer)
Miembro
I'm upgrading from a 3S+ with the upgrade kit ... and in step 13 of the manual it has you insert a spacer 13x24x2.5 into the PG-front-case    I have been through all the parts bags several times ... and I can't even find a bag that has that part listed on it let alone the part.
What am I misunderstanding?   Is the manual out of date (I am using the one from the Prusa site) maybe?   I can't find a part anywhere close to what that spacer says it is or looks like....
Respondido : 20/05/2025 10:06 pm
iftibashir
(@iftibashir)
RE: Missing a part? or is the manual out of date?
Do you have a link/image from the manual showing the part?
Respondido : 27/05/2025 9:12 am
Sembazuru
(@sembazuru)
Are you upgrading to a MK4 or a MK4S? Both my memory of building my MK4 then upgrading to the MK4S and looking at the current assembly guides, the MK4 has a 3D printed planetary (PG) gear cover and the MK4S has an injection molded PG cover. The 3D printed PG cover needed a spacer (as I recall when I built my MK4, my spacer was white and I had to install it in the cover, but the picture for the MK4 kit assembly shows a black spacer already installed in the cover) between the planet gears and the cover. The injection molded PG cover got rid of the need for that spacer.
See my (limited) designs on:
Respondido : 27/05/2025 3:57 pm
