Loud noise and strong vibration when moving along Z-axis
Dimagog
(@dimagog)
Mitglied
Finished building my mk4s kit. I’ve paid careful attention during Z-axis assembly and aligned rods almost perfectly.
Calibration went fine (all green), and first prints are looking good.
Yet still, when print head is moving quickly along the Z-axis it makes loud noise and the whole table vibrates significantly. Not during normal printing but when it decides to go all the way up, or all the way down to home position.
The vibration and noise seem stronger at the bottom.
How should I fix it? My current thoughts are loosening bolts holding the Z-motors, and/or loosening bolts holding Z-bearings.
Veröffentlicht : 14/09/2024 11:36 pm
iftibashir
(@iftibashir)
RE: Loud noise and strong vibration when moving along Z-axis
Remove the top brackets of each Z axis (where it attached to the frame at the very top). Then remove the trapezoidal nuts.
Check to ensure your Z motor rods are in the center of the plastic printed parts - they must not touch the plastic parts at all, but the more centered the better. Tighten or loosen the bolts on the Z axis motors to ensure the rods line up well. Then reattach the trapezoidal nuts and top brackets.
Finally recalibrate Z axis.
Veröffentlicht : 16/09/2024 11:05 am
Dimagog
(@dimagog)
Mitglied
Turns out spiral Z-rods were bone-dry. After lubricating them the things have improved.
The irony is that I was only handling them with plastic gloves in order to not remove the supposed at-factory lubrication, and that’s prevented me noticing that they are not lubricated at all 😌.
Veröffentlicht : 18/09/2024 7:43 pm
ductng
(@ductng)
I had the same problem with my Core One Assembly Kit. I was afraid that the Z-axis rods were not straight and caused the vibrations. After lubrication the noise is gone now!
Veröffentlicht : 11/08/2025 11:17 pm
