Layer gone haywire stringing?
shugobha
(@shugobha)
My first prints on default PLA settings went great but then part 2 of a 2 plate print did this, I changed it to a new file with default Prusament PLA it was going fine I hear a scraping sound turn around see it's happened again an hr or so in. I'm going to attempt a temperature tower but I am inexperienced if anyone can easily tell me what's up? It seemed to be fine on the xyz callibration.
Best Answer by Diem:
OK, check your grub screws.  See: Step 26 on https://help.prusa3d.com/guide/3-x-axis-x-carriage-assembly_707749
Ce sujet a été modifié il y a 1 year par shugobha
Publié : 21/01/2025 3:02 pm
Is this a prebuilt machine or a kit?
I suspect you my have a wrongly assembled X drive gear.
Publié : 22/01/2025 4:14 am
1 personnes ont aimé
shugobha
(@shugobha)
RE: Layer gone haywire stringing?
Kit Yes, I wondered that, I was pretty confident with most of it but wondered if I didn't tighten something in X axis properly I think it suggested leaving motor loose while adjusting belt tension not sure if I've done something wrong there. Was doing MK4 with S upgrade at same time. It is weird it did several successful prints before this though if it was a problem from the start?
Publié : 22/01/2025 4:30 am
Publié : 22/01/2025 10:34 am
Ineal
(@ineal)
Posted by: @diem
not only the screws, the alignment of one screw an the flat part is more importend
Publié : 22/01/2025 10:57 am
shugobha
(@shugobha)
Thanks! I did an XYZ test after the failed one and indeed X failed, I wondered if manually moving it to the left and setting it as zero would fix it as it had worked on my initial Z fail, sure enough it did pass the test then, so as an experiment since it claimed everything was ready to go I just hit print again on it.
For a while it was still clipping the prints, the items are like a bowl shape and my suspicion is that either humidity or temperature has caused them to curl up, I lowered the speed to 50% when it was clipping them and the following layers turned out much cleaner, didn't want to wait 18hrs so have put it back up to 80% and so far so good, I think it will be okay now that the bowl shape has more structure. Thanks for all the suggestions I will double check those parts after this experiment.
Ce message a été modifié il y a 1 year par shugobha
Publié : 22/01/2025 11:57 am
shugobha
(@shugobha)
Publié : 22/01/2025 12:04 pm
shugobha
(@shugobha)
Publié : 22/01/2025 12:07 pm
