First few layers of a print are rough
Hi - I've just moved from an UpBox printing ABS to a Prusa Mk4 with PLA and am slowly trying to get to grips with the settings to get a good quality print. With the ABS/UpBox, I printed a raft and the model detached from the raft very cleanly leaving a smooth surface. I have tried the PLA/Prusa with and without a raft but I get the sort of surface shown in the photo (although the rest of the print is OK). Can you please suggest settings that will result in a smooth base of the model. I'm running 0.2mm layers but left the first layer at the default 0.35mm. Perimeters 30mm/s.
Thanks
Richard
RE: First few layers of a print are rough
Hello Richard, I see that you are printing ABS. That usually requires a heated enclosure as ABS warps easily.
OP is printing PLA on the Prusa, so enclosure is not required (although it will be for ABS of course).
OP - the first layer should be completely flat - seems like you do not have enough 'squish', although the MK4 should do this automatically. Does it go through the calibration and bed probing successfully before the print begins?
Make sure the part is flat on the plater.
Thanks
Richard
If by "heated enclosure" you mean actively heated enclosure, no - absolutely do not need a heated enclosure. I have hundreds of hours printing ABS without a heated enclosure. A enclosure yes - but not an actively heated enclosure. ABS is the recommended filament in Voron builds and most of us are using Voron's with just a standard non-actively heated enclosure to print ABS.
As to the OP - does this first layer issue happen with your other prints? As others have already mentioned - if you've gone through the calibration process, you should then get pretty much spot on first layers. If its isolate to this print only with PLA - and that looks like prusament galaxy PLA - I would start looking at things in your slicer
