Filling print issue
frederic.b
(@frederic-b)
Filling print issue
Hello,
What could cause this issue  ? First time I have that
Thanks for your help
Respondido : 09/10/2024 8:04 am
iftibashir
(@iftibashir)
RE: Filling print issue
Any bumping noises while printing the infill?
Wonder if the nozzle is hitting the raised part of each layer, where the layers cross in the infill....
Respondido : 09/10/2024 11:26 am
Artur5
(@artur5)
I guess you're right.
That filament seems Prusament PETG neon green. PETG isn't the easiest material to deal with and, in my experience, Prusa's neon green  is even more finicky than other colors. Changing the infill type should help to alleviate or fix the issue. I suspect too that reducing the infill speed and possibly the nozzle temperature a few degrees would help even more.
Respondido : 09/10/2024 3:24 pm
frederic.b
(@frederic-b)
Thanks for your feedback
@Iftibashir : Yes the nozzle hit material at every infill cross
@Artur : Material is colorfabbXT.
After my message I printed the compionent with Prusa PETG without any concern. May be moisture in colofabb material. Will try to dry it and see.
Respondido : 09/10/2024 4:04 pm
iftibashir
(@iftibashir)
I find the gyroid infill works better as the nozzle doesn't hit anywhere near as much.
Respondido : 09/10/2024 4:31 pm
