RE: Filament broken off in Nextruder - hints on removing needed
You should be able to pull it out of there with needle-nose pliers/tweezers. Heat the hotend up to standard print temperature to make sure it's not stuck with the other end to the nozzle. I've never had to open the gearbox to remove stuck filament.
Napsal : 06/01/2025 1:26 pm
