Using GPIO for loadcell integration?
berlincount
(@berlincount)
Utenti
Hi all 🙂
I'm wanting to use https://www.printables.com/model/1196950-filament-weight-scale-spool-holder-prusa-core-one or even https://www.printables.com/model/1370600-1kg2kg-filament-weight-scale-spool-holder-prusa-co to get a rough weight or % estimate to be able to guesd how much still is on the spool, and when I need to be prepared to switch spools ...
I'm guessing it should be possible to integrate this via the GPIO board, but would probably need some firmware modification than the current API allows, let alone to get to see this in Prusa Connect?
any advice welcome,
  count
Postato : 09/02/2026 1:07 am
