GPIO and parameter names
LarGriff
(@largriff)
Is there a list of valid parameter names that can be referenced by gcode in communication with the GPIO board?  For instance, I want to press a couple of buttons to enable/disable “Ready Mode” and I’d like an output to turn on a light when “Ready Mode” is active.  Where would I find a reference of all available parameters?  Thanks.
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Veröffentlicht : 31/01/2025 4:36 am
_KaszpiR_
(@_kaszpir_)
RE: GPIO and parameter names
https://help.prusa3d.com/article/gpio-module_734695
There is a section about setting pin state via gcode
Veröffentlicht : 31/01/2025 9:20 am
LarGriff
(@largriff)
Thanks.  I’ve read the GPIO page.  Very sparse information there.  My question is more about parameter names within PrusaSlicer that can be used with GPIO gcode.
Sorry about the double posts.  The forum search was a dead end.
Veröffentlicht : 31/01/2025 2:15 pm
_KaszpiR_
(@_kaszpir_)
You cannot do too much because gcode will be baked in and anything needs to be as triggering gpio pin (output) or executing gcode script from the pendrive if given gpio is triggered (input).
Also some printers do not support certain commands on the firmware, so the question is what do you want to do exactly.
Veröffentlicht : 31/01/2025 2:20 pm
LarGriff
(@largriff)
I want to turn on a GPIO output based on the “ready” state of the printer.
Veröffentlicht : 31/01/2025 3:27 pm
QMcMurray
(@qmcmurray)
I think that we are try do do the same thing.
I'm thinking that that the M72 command can be used for what you're trying to do but I'm having issues understanding it.
https://help.prusa3d.com/article/prusa-firmware-specific-g-code-commands_112173#m-commands
It doesn't have a lot of information on how to use it though.
Veröffentlicht : 01/02/2025 3:52 am
LarGriff
(@largriff)
Welcome to the bleeding edge!
There’s also this OTHER list of gcode commands.   https://help.prusa3d.com/article/buddy-firmware-specific-g-code-commands_633112
I THINK the buddy specific version applies here but it doesn’t even mention M72.
Posted by: @qmcmurray
Veröffentlicht : 01/02/2025 3:00 pm
QMcMurray
(@qmcmurray)
Thanks!
That's a good point. I didn't consider that there would be a difference between the two lists.
Looking at the page, there's a note right at the top for what printers use what firmware.
They're almost the same, which is frustrating, and nothing that I can see will set the printer stratus via gcode.
Veröffentlicht : 02/02/2025 3:04 pm
LarGriff
(@largriff)
I got an email from customer support today saying there is no way to read the Ready status with gcode, but you can Set Ready with M1200.  No documentation or examples were supplied and I haven’t tried it, but FYI.  Good luck!
Veröffentlicht : 02/02/2025 3:44 pm
QMcMurray
(@qmcmurray)
Thanks for the Info!
That'll help with my project.
If I discover anything to read or Set the printer status I'll be sure to report back!
Veröffentlicht : 02/02/2025 3:47 pm
Valjuvic_2
(@valjuvic_2)
Mitglied
Happy to have found this thread, was looking for this.
I tried the M1200 without success on a prusa mini, any success on your side ?
Veröffentlicht : 24/02/2025 6:44 pm
