Smooth surface
Marc
 Marc
(@marc-14)
Smooth surface
https://www.printables.com/model/666520-parameterized-cuban-chain/comments/1559914
Prusament PLA Blend Viva La Bronze
MK4 Input Shaper 0,15 structural, 2 perimeters, 15% infill. Scaled the spiral chain 10 links to 160%. The length is then around 155mm.
I want the  flat surface part more evenly. Perhaps more perimeters?
Any advice is welcomed!
Opublikowany : 24/02/2024 3:11 pm
RE: Smooth surface
turn ironing on?
Opublikowany : 24/02/2024 4:00 pm
Brian
(@brian-12)
RE: Smooth surface
Print it with PVB, or ABD and vapor smooth it.
Opublikowany : 24/02/2024 4:13 pm
AnnieR
(@annier)
RE: Smooth surface
I've had fairly good luck doing vapor smoothing.
This is an earring pendant I did a couple of years ago. I know it's not crystal clear but surfaces are smooth and shiny.
Hatchbox transparent ABS smoothed by hanging in a jar with acetone in the bottom.
Opublikowany : 24/02/2024 5:24 pm
1 ludzie polubili
Brian
(@brian-12)
RE: Smooth surface
Sorry I miss typed, ABS not AVB
Opublikowany : 24/02/2024 5:37 pm
Marc
 Marc
(@marc-14)
RE: Smooth surface
I’ll give this a try
https://help.prusa3d.com/article/ironing_177488
Posted by: @fuchsr
turn ironing on?
Opublikowany : 24/02/2024 11:58 pm
Marc
 Marc
(@marc-14)
RE: Smooth surface
Thx. I think PLA should do the job if the settings are correct
Posted by: @brian-12
Opublikowany : 24/02/2024 11:59 pm
Marc
 Marc
(@marc-14)
RE: Smooth surface
Thx. I’m familiar with this technique. I just have the feeling it that there should be more to get out of the print settings  to make it smoother .
Posted by: @annier
Opublikowany : 25/02/2024 12:01 am
