Small layer shift on the opposite wall of the threads
Hello, I came across a strange issue while printing threads. I am printing this small container
There are threads inside.
As you can see in the first picture, there is a strange bulge on the outer side that copies exactly the path of the inside thread. But the walls of the object are 1.5 - 2 mm thick (the wall thickness is changing because of the waves).
Why am I getting this? The bulge is really small, it sticks out maybe 0.05 - 0.1 mm but it's visible.
I thought it's layer shifting so I checked belt tension. But I printed it twice with the same result on the same position.
I also checked the model and there's no bulge in the mesh.
Print details
Printer: MK4
Material PLA
Default PrusaSlicer settings.
Thanks for your suggestions.
Este debate ha sido modificado el hace 2 years por sufliky
Respondido : 07/03/2024 2:57 pm
