RAGE @ Galaxy Black Prusament Free roll.
Paul Harbin
(@paul-harbin)
This dance I am doing to try and get this stuff to stick is absolutely bonkers.  I love my poly terra Charcoal Black so much.  I cant even print one mini let alone a bed full .... it's dried for 8 hours ... trying 70 on the bed now ... Should I break out glue for the smooth sheet? Poly terra is almost a fight to get it off at 60 ......cost less and I spend less money to print it because I dont need glue .... or more heat.  /rage. =)
Veröffentlicht : 30/08/2023 8:12 pm
Paul Harbin
(@paul-harbin)
To note, that's a .4 ObXidian Revo on the MK3S+ that did that. I rushed the last few minutes with messed up the sword end and horn tips so I could throw another print on before I went back to work. >< The mini in the Foreground is off the MK4 and .25 nozzle X adapter with PolyTerra CB.
Veröffentlicht : 30/08/2023 8:54 pm
jseyfert3
(@jseyfert3)
RE: RAGE @ Galaxy Black Prusament Free roll.
Like it won’t stick to the bed? I had no issues with my free roll of Galaxy Black and sticking to the bed.
Veröffentlicht : 31/08/2023 1:09 am
Paul Harbin
(@paul-harbin)
I have only achieved adhesion at bed 70 .... also using glue because I would like to use it, the filament that is.  And to be clear, the same exact sheet printed fine @ 60 for the PolyTerra. All setting exactly the same with exception for filament profiles. There are apparently batches where this happens. I suspect it has to do with a bad mix of the "flakes" in the black. Will experiment a little more with actual print temps now that it is not coming off the bed.
Veröffentlicht : 31/08/2023 7:48 am
Paul Harbin
(@paul-harbin)
To be doubly clear, I printed what the P-GB failed at with PT-CB directly after the fail to "check" the sheet.
Posted by: @paul-harbin
Veröffentlicht : 31/08/2023 8:47 am
Paul Harbin
(@paul-harbin)
So
Veröffentlicht : 31/08/2023 11:33 am
Paul Harbin
(@paul-harbin)
After the first two sticks ... let's jump.
Veröffentlicht : 31/08/2023 11:34 am
