Prusament PETG Organic supports issues
Whenever I try to print organic supports with Prusament PETG (2 different spools, one brand new) and I get the result below.
This is with double walls and support speed set to 75 from original 120 mm/s.
Typically no other issues in my prints, just this very annoying blocker - any ideas?
Postato : 06/05/2026 6:08 pm
Try rotating the part on the print sheet - does the flaw persist? If so does it rotate with the part or remain in the same orientation with respect to the printer?
Postato : 06/05/2026 10:21 pm
