[Risolto] Prusa MK4 missing lines randomly
Pagina 3 / 3
mjkobb
(@mjkobb)
RE: Prusa MK4 missing lines randomly
Are you actually able to print from Connect via Wi-Fi with that build? My understanding was that Connect was broken on Wi-Fi with alpha 1.
Postato : 28/09/2024 4:15 pm
Printerman
(@printerman-3)
Yes, its working very nice over Prusaconnect with 6.2.0 Alpha 1, using upload and print with Prusaslicer. I printed a few more benchys, and they all came out perfect. Im not sure what fix in the Firmware that did the trick, but it works.
Postato : 29/09/2024 1:21 pm
mjkobb
(@mjkobb)
Okay, well, I updated my XL to 6.2.0 alpha 1 and it will not connect to Prusa Connect at all. The status on the LCD says "refused".
One note: the Wi-Fi showed as non-functioning after the software update, until I reset the printer. Then the network came up and it has an IP address, but Prusa Connect is refusing connections. I changed the connection to Ethernet, which requires leaving a door open into my garage and running a 50' Ethernet cable, and the printer connects just fine.
So, if you're relying on Wi-Fi for your printers, I would definitely advise against 6.2.0 alpha 1 for now.
Questo post è stato modificato 1 year fa da mjkobb
Postato : 30/09/2024 12:42 am
mjkobb
(@mjkobb)
I've been using my XL for the past week with the 6.2 alpha 1 firmware. As noted above, this release breaks Wi-Fi, so I've been using Ethernet, but I have not seen the missing perimeter issue during this time.
Now Prusa has released 6.2 alpha 2, which fixes the Wi-Fi breakage. But it seems that all they've done for that fix is to revert the prior change, so I fear that it will reintroduce the missing perimeter bug.
Postato : 05/10/2024 5:32 am
Printerman
(@printerman-3)
My MK4 has had no issues with the WiFi, and printing without missing perimeters. Could it be a XL specific issue? Please keep us updated on your experience with 6.2 Alpha 2
Postato : 05/10/2024 7:45 am
mjkobb
(@mjkobb)
No, I had the issue first on my MK4. The issue seems to be whenever Prusa Connect is used. If I disable Connect, it's fine, but of course I lose the functionality of Connect, which I want.
Postato : 05/10/2024 8:02 am
Printerman
(@printerman-3)
I printed some benchys with 6.2.0 Alpha 2 on my MK4, it still works and have no artefacts or missing lines with my printer.
Postato : 12/10/2024 12:00 pm
black kvader
(@black-kvader)
Utenti
Hello, the issue is closed on github, but I have skipped line in my print. I switched from prusaConnect to prusaLink, and will see if this issue will repeat. Is there a chance this was not solved after more than a year? Thank you for this thread, I didn't understand what is going on as the printer prints otherwise super clean
Postato : 04/05/2025 9:33 am
Printerman
(@printerman-3)
Sorry for the late reply, i think that the problem is resolved. I haven't had any issues with missing lines in my prints since the update.
Postato : 07/07/2025 8:55 am
mjkobb
(@mjkobb)
I agree. My printers are running latest firmware and I have not seen the problem occur since they were updated.
Postato : 07/07/2025 7:07 pm
Pagina 3 / 3
