        Problems with corners on low layer height
I am trying to print some miniatures at .05mm layer height. Some of the corners I am printing are significantly deformed and are ruining the print. I am pusing polymaker polylite pla that I have dried.
I tried it at .2 mm later height and didn’t have the same issues. Any ideas of what is causing this?
                            Veröffentlicht : 02/11/2024 8:08 pm
                    Why such shallow layers?
As a rule of thumb layer height half the nozzle diameter is the best starting point. The smaller the layer the trickier the print and by one eighth *everything* has to be spot on. My first thought is: make sure the filament is absolutely dry.
                            Veröffentlicht : 03/11/2024 6:33 am
