Problème de trous dans mes impressions
Louis Goutaudier
(@louis-goutaudier)
Hi everyone, I'm having an unsolvable problem. I have micro-holes in my prints. I've tried everything, increasing the flow, decreasing the flow, reducing the speed, using very dry filaments, but nothing works. I constantly have this problem. There must be something I'm not managing properly. For information, I use Polyterra filament from Polymaker, I heat it to 215, on a 50° plate. On the MK4 I limit the print speed to 70 mm/s as recommended by Polyterra for their filament. And despite all that, I still get these little holes.
What do you think? What could be the cause?
Opublikowany : 16/04/2024 6:17 pm
