Printing problem
Fred
 Fred
(@fred-7)
Utenti
Printing problem
Hello,
I have 30 printers MK3 and one MK4 until now no problem on a part that I wanted to print on MK4, it does not work I'm not even in MK4IS just in MK4 normal with speeds lowered to 80 mm / s filling Rectilinear on both, I tried to increase the temperature of 10 ° C but nothing.
I'm working on this part with PETG Jet black prusament
if anyone has any ideas, I'd love to hear from you.
Best regards,
Postato : 08/10/2023 9:29 pm
Rainer
(@rainer-2)
RE: Printing problem
Do you have a problem only with this part or basically with the MK4?
To me it looks more like it's printing too hot. Does the part hold on the bed or do you have warping?
Belt tension correct? With the MK4 rather a little more than too little tension. You know the Belt tuner for tensioning?
Which firmware? I would load the latest firmware. In the slicer, select the input shaper MK4 and print with the 0.2 structural with standard settings.
Postato : 09/10/2023 7:54 am
Fred
 Fred
(@fred-7)
Utenti
Hello,
Thank you for your reply, yes I know the belt tuner, but I'll have another look, otherwise firmware 5.0.0, the temperature is the same as on the MK3. No distortion, all is ok on this side.
And this problem is only in PETG, otherwise here we only print ABS Fire proof practically.
Je refais un test en IS
Postato : 09/10/2023 9:16 am
