Printing a part with a strong magnet. Print head fan fails.
Sitcom8978
(@sitcom8978)
Mitglied
Hi! Any idea how to overcome this issue?
I'm trying to print a magnetic cup holder. After the print pauses and I insert the magnet I cant get it to continue because the print head fan stops when it passes over the magnet and the Prusa Mk4 throws an error and stops. I'm sure the BLDC fan motor cant overcome the strong N48 magnet.
Veröffentlicht : 05/11/2023 7:44 pm
RE: Printing a part with a strong magnet. Print head fan fails.
Can you turn fan monitoring off, in the LCD Menu?
Not ideal, but may get you over this print.
Veröffentlicht : 05/11/2023 7:57 pm
Sitcom8978
(@sitcom8978)
Mitglied
Turning the fan monitoring off did allow me to get though it however without the fans functioning as intended the print is unusable after I continue it. I'll need to split this into 2 separate parts and glue them after.
Veröffentlicht : 08/11/2023 11:32 pm
Can you cut a magnet shaped core out of the model rather than splitting the model, so that the outside remains un damaged, then install the magnet and a printed core filler, to hold the magnet in place?
Veröffentlicht : 09/11/2023 2:03 am
