Printed Circle Diameters Different
When I print these two parts, the diameter of four 6.28 mm circle cutouts on the left part print perfectly. For the right part, the diameter ends up being printed slightly larger for the four cutouts. The cutouts hold 6 mm x 3 mm magnets which press in tight on the left part but fall out on the right part. I increased the diameter of the circles by 0.28 mm to adjust for tolerance which was the result of the tolerance test parts that I printed.
So, what can I do to make the circles the same? Is this an XY size compensation issue? If so, if I modify that won't it affect all of the circles?
Respondido : 10/07/2025 3:53 pm
