Prime after pause print
SmartMart
(@smartmart)
Hi all,
I am currently doing some prints where I pause the print with an M601 command, insert some hardware into the print and then continue the print. The problem is that while I am inserting hardware, some plastic oozes out of the nozzle, resulting in a temporal underextrusion when the print continues. This in turn results in bad layer adhesion and visible wall gaps.
Is there a way to make the printer prime immediately before continuing the print in the same way it does after a manual color change? That way the nozzle would be filled and the defect wouldn't occur. I know I can work around it by using the M600 command instead, but that's just annoying as I have to unload filament, then load the same filament again.
Opublikowany : 19/12/2023 2:50 pm
MartinMadsen1
(@martinmadsen1)
RE: Prime after pause print
*bump*
Having same issue. I'm thinking I need to add a line of gcode after the M601 to extrude some filament then resume... but have no idea how. Anybody else had this / a fix?
Opublikowany : 15/12/2024 8:50 pm
