MK4 with MMU3 Bridging Infill
UntestedEngineer
(@untestedengineer)
I have a need to print the following object with the recess facing towards the plate so I need to use supports.  This object is a smaller version of the real object so I am trying to use less filament and getting the print right before wasting more on the larger object.  As you can see the Bridging infill for the cross pieces isn't the best.  My original intent was trying to print this with PETG (Generic brand) but it comes out even worse than Prusament PLA.  I have tried: lowering Bridging Flow Ratio to .8 then .7, lowering Bridges speed from default to 30 mm/s to 22 mm/s, increasing the Bridging angle to 90 and 180.  Removing the Support Interface layer to no avail.  What else can I tweak?
MK4 with Firmware 6.03 and MMU3 (latest firmware).
Prusament PLA (Looks slightly better but not what it should be)
Generic PETG (Looks worse)
Respondido : 25/07/2024 4:43 pm
