MK4 + Prusament PETG + 0.6 nozzle = print issues
vrata48
(@vrata48)
Hello,
I'm printing this sphere with 3mm thick walls that has another sphere inside and I get this weird print issue on external side (on both objects). I tried multiple times and always got the same issue. There are more problems in the print but this is the major one. I'm not much into fiddling with printer itself but I checked the belts and their tension is ok (according to Prusa app).
I'm using default profiles, no supports, the filament is Prusament PETG and nozzle is 0.6.
All looks good in slicer, no warnings etc. This is the orientation in slicer:
This is the print.
Any help will be appreciated. Thanks!
Best Answer by vrata48:
So I contacted the support and they told me that I should increase nozzle temperature to 255 (while using input shaper) which surprisingly fixed the issue.
Publié : 18/03/2024 3:16 pm
Me
 Me
(@me-2)
RE: MK4 + Prusament PETG + 0.6 nozzle = print issues
that looks like a cooling issue, the mk4 has asymmetrical cooling so that is why it's only on one side (is far as i can see).
try slowing down overhang speeds in plusa slicer / checking your filament profile cooling settings.
supports might help.
Publié : 18/03/2024 3:59 pm
1 personnes ont aimé
vrata48
(@vrata48)
Publié : 20/03/2024 10:51 am
Rui Guerra
(@rui-guerra)
I'm curious about what this model is. Looks like some sort of mechanical support with an articled head?
Thanks
Publié : 23/03/2024 10:08 am
vrata48
(@vrata48)
Its tripod for mobile phones base.
Publié : 23/03/2024 9:22 pm
Jon Bondurant
(@jon-bondurant)
Membre
This worked great for me too with a HF0.6 nozzle and PETG.  I seemed to get better results with 0.20 and 0.25 layer height, but slightly worse with a 0.15 lh and PETG for functional models with fine pitch threads. YMMV, though!
Posted by: @vrata48
Publié : 22/02/2025 4:51 pm
