MK4 keeps giving me File error
WUSTANG Build
(@wustang-build)
Can anyone assist me with getting my printer to read my "NEW SanDisk 64" as soon as I enter it, the printer throws the error code "File error/ Failed to open file" my printer was working fine. I didn't use it for a couple months and I comeback to it and then all of a sudden nothing works.  What is odd is that i can enter the Prusa USB that came with the printer and lets me print the scraper without a fluke. Also, i noticed what changed is, before it would give me an image of what it was going to print and now it doesn't. I have spent several hours with Prusa and have requested i buy new USB did that, update to 6.0 done that, then downgrade back to the one before (5.1 or whatever it is) and nothing seems to let me print a new file. I'm only trying the files that others have uploaded on Prusa site and then open in slicer (latest version) if anyone can help me I would appreciate it so much. Willing to compensate someone that's willing to show me what I'm doing wrong and get it to print a file. thank you for any help community
Opublikowany : 13/05/2024 9:11 pm
Whereabouts in the world are you (not street address)? Perhaps someone in the same country can arrange to swap a drive with you and check the basics..?
Opublikowany : 14/05/2024 12:09 am
WUSTANG Build
(@wustang-build)
RE: MK4 keeps giving me File error
im the USA ( Arizona) thank you for the help
Opublikowany : 14/05/2024 2:24 am
CyclonEngr
(@cyclonengr)
Not sure if this is relevant, but I believe you need to have FAT32 format and I think some people have had problems with USB sticks larger than 32GB.  Sometimes there are corrupted (or hidden) files on the stick after power failure or caused by other/unknown issues that prevent the USB stick from being 'read' by Prusa printer.
p.s. I'm in Iowa . . .
Opublikowany : 16/05/2024 4:29 pm
I'm in the UK so too far for sensible postal swaps.
Is there anyone in SW US able to A) Send a known good USB stick with a sample file and B) Accept, test and analyse a suspect one?
[ I use SanDisk USB which arrive formatted in a manner that just works out of the box - it might be necessary to partition to sub 32GB as @cyclonengr suggests or, the OP might have been sold counterfeit drives, there were a lot about a couple of years ago. ]
Opublikowany : 16/05/2024 7:13 pm
WUSTANG Build
(@wustang-build)
I will certainly try a 32GB scan disk , i got a 64 scandisk cause that's what the lady suggested. I will order new ones and try it out.
*********** The thing i find so odd is i can print the files that came with the purse starter kit , which included the spatula , the rocket engine and a couple more. So the printer itself is working , just something to do with the files off slicer or maybe the downaloads. What program comes with the purse out of the box ? I still have the updated 6.0 .
An thanks again everyone for taking the time out and help out with some input
Opublikowany : 17/05/2024 1:00 am
you should be able to re format the 64Gb Scandisk with FAT32 (On your computer), and make it work on your printer.  without having to wait for a new memory stick to arrive
regards  Joan
Opublikowany : 17/05/2024 9:11 am
WUSTANG Build
(@wustang-build)
Thank you Joan i will try that
Posted by: @joantabb
regards  Joan
Opublikowany : 19/05/2024 7:45 pm
