MK4 fan shroud upgrade
mself52
(@mself52)
Miembro
I have attempted at least 10 times to print the fan shroud that wraps around the nozzle, I’m doing it in ASA and not having any luck! I was able to print one on my mk3s+ in ABS…. The mk4 seems to be trying to print too fast, anyone have any recommendations?
Respondido : 21/07/2024 6:23 pm
mself52
(@mself52)
Miembro
RE: MK4 fan shroud upgrade
So I think I found an issue, even though in the slicer I selected asa and it says nozzle temp 260 after I move to print the printer is only showing nozzle temp 170?!? I have to manually change the temp on the printer
Respondido : 21/07/2024 11:05 pm
Mk4 printers have 2 stage heat up, 170 before bed levelling, then full temperature
Respondido : 21/07/2024 11:25 pm
mself52
(@mself52)
Miembro
Thank you! That makes sense, it was the belts they were very very loose. I followed the instructions and tightened them and it’s running much better!
Respondido : 22/07/2024 6:04 pm
