How to make extrusion multiplier and print head temperature change mid- print
Jimtom
(@jimtom)
I am using Varishore TPU filament. I want the bottom solid layers printed at 220º and extrusion multiplier setting of .7, then change to print infill layers at 190º and extrusion multiplier of 1.1. Can I do this with a height range modifier in PrusaSlicer?
Opublikowany : 23/07/2024 4:22 pm
If you make a copy of your printer profile with multiple (fictional) extruders you can use a modifier to change extruder - which means loading all of the new extruder's settings.
Opublikowany : 24/07/2024 4:27 pm
