        FLEX filament print failure
I want to print a item from FLEX Fialment (Fiberlogy FiberFlex 30D) using included PrusaSlicer profile for that filament, but what I get doesn't seems to be good. It looks good on the first layer, but the the result is as in attached photo. I have included the 3MF project file for reference.
                            Opublikowany : 20/09/2024 8:56 am
                    RE: FLEX filament print failure
- check for tension. If there is too much resistance the filament get's streched resulting in a reduced diameter.
- reduce "max volumetric speed" in the Filament->Advanced section
                            Opublikowany : 20/09/2024 9:32 am
                    You are slackening the extruder idler pressure as suggested on:
https://help.prusa3d.com/article/flexible-materials_2057
                            Opublikowany : 20/09/2024 10:26 am
