Filament change on every print?
drllama
(@drllama)
I'm puzzled. On every print, I see the following happen:
  1. Bed probing, that's fine
  2. Purge line, that's also fine
  3. Immediate filament change, huh?
  4. printing normally after reloading the same filament.
Any idea what's causing #3? Is there a setting I should have to avoid that? It seems very strange that immediately after the purge line, the head pops up and unloads the filament, prompting for a filament change?
Puzzled!
Best Answer by drllama:
I found a solution. Looking at the gcode, I saw an M600 command (filament change) early in the file.
Switching to PrusaSlicer 2.6.1-rc1, the same profiles, the gcode no longer has the M600, so it seems that this has been fixed in 2.6.1!
Cheers,
Bruce.
Posted : 30/08/2023 9:23 pm
drllama
(@drllama)
RE: Filament change on every print?
Worth noting, I'm using PrusaSlicer 2.6.0 with the Mk4 profile, only thing I've changed is to use Gyroid infill.
Posted : 30/08/2023 9:30 pm
Antonio
(@antonio)
Member Moderator
weird!
Have you tried to re-run the fil.sensor calibration?
I'm not an expert. Ma parlo anche italiano 😉
Posted : 31/08/2023 10:34 am
drllama
(@drllama)
Cheers,
Bruce.
Posted : 31/08/2023 2:08 pm
Ckobar
(@ckobar)
Hi, drllama, did you manage to change the standard infill in systems settings.  If so, how did you do that ?
thank you
Posted by: @drllama
Cheers,
Bruce.
Posted : 14/09/2023 11:43 am
drllama
(@drllama)
Updating to the newer version of PrusaSlicer was all I did in the end. Apparently it was a bug in the slicer...
Posted : 19/09/2023 6:36 pm
