Changing filament type PETG to PLA. Best approach
Stecas
(@stecas)
Hi
I plan to buy a MK4 that I want to replace two old printers.
One with only PLA and one with only PETG.  Going from PLA to PETG on the same printer is undramatic.
But from PETG to PLA is tricky due to different melting points.
Is there any good method to clean PETG hot end before printing PLA or other filament for that matter?
I have always had a dedicated printer for each filament type.
Any hints/approach are most welcome.
Napsal : 29/05/2023 10:38 am
Walter Layher
(@walter-layher)
RE: Changing filament type PETG to PLA. Best approach
Repeat the purging several times when you change the type and perhaps print a small test object that is not important before the next important part.
Napsal : 29/05/2023 11:17 am
Stecas
(@stecas)
Thanks Walter for your reply
If I understand it right: I purge the printer with PLA (after a PETG job) att PETG temperatur (260 degrees) in order to get rid of all PETG.
Then I conduct  a test prints with PLA at PLA temperatur (210 degrees give or take)
Stephan
Napsal : 29/05/2023 11:33 am
When changing from a higher melting temperature filament to a lower one, change at the higher temperature and purge the lower temperature filament at the higher temperature.  This should clear out the old filament OK, if not done this way partial clogs are common.
Napsal : 29/05/2023 12:02 pm
Stecas
(@stecas)
Thanks a lot.
That make sense.
Napsal : 29/05/2023 12:08 pm
As diem said. Or run a short length of cleaning filament through.
Napsal : 29/05/2023 2:04 pm
Stecas
(@stecas)
Cleaning filament. Perfect. Just read about it: https://all3dp.com/2/3d-printer-cleaning-filament-what-you-need-to-know/
Napsal : 29/05/2023 7:41 pm
jsw
 jsw
(@jsw)
I run PLA, ABS, and PETg in the Prusa (and the Ultimaker) regularly and ASA and PC Blend occasionally.
I will often swap between PLA/ABS/PETg and I've never had issues.  The only annoyance is the color, and often times when going from something like black to something like white it takes 3-4 'is the color correct?' cycles for it to be really truly correct.
I will usually swap at the temperature of the higher temp filament, but sometimes space it off.
The one time I had an issue with a higher temp filament is when I did some PC Blend prints and let the PC Blend sit in the machine overnight.  I had to REALLY heat it up in order to purge the PC Blend out.  Now when I do PC Blend printing I will purge it with ABS after the last PC Blend print.
Napsal : 29/05/2023 9:24 pm
Stecas
(@stecas)
Thanks for info.
Posted by: @jsw
Napsal : 30/05/2023 8:02 am
