RE: Cannot Slice
save a copy of your Project file for the model,
Zip compress it,
Attach the Zip compressed file
RE: Cannot Slice
thank you,
what are you actually trying to achieve?
you appear to have the main STL, Turned Off
If you click on the eye symbol which is hilighted in the first picture, the model should become sliceable
it looks like you at trying to remove the branding from the box,
your SLAB, does not cover the entire bottom of the box,
and your question marks do not quite line up with the marks on the sides if the box... in addition to being set too deep
you might be better using slabs instead of question marks...
RE: Cannot Slice
I've been printing for over a year and never realized that eye selected the object. Thank you!
