Z-homing/calibration
so my printer was fine yesterday morning until I got a clog of FLEX filament. I unclogged fine but now here's what happens,
1. when I try a new print, if the print head isnt at least 100mm from the bed, it comes down, then stops, goes up a little and down a little then says either
a) collision detected (although there was no collision, or
b) it resets and says error with Z
2. when I recalibrate Z it will try and fail then when I run again its fine.
after this, the printer will be ok for a print or two but then go back to the same issue.
before it would just come down and with will detect the bed easily. I tried to reconfigure and it will work sometimes
Publié : 18/07/2025 3:04 pm
