Z Axis Calibration failing
Adjutantman
(@adjutantman)
My Mk4 suddenly started failing it's Z axis calibration - when I started my most recent print, instead of tapping the build plate, it rammed the nozzle down so hard I thought it might actually bend the plate, and then started grinding the stepper motors in an effort to push it further through. I reran the calibration, including the load cell thinking it might have gotten out of whack. The load cell failed repeatedly until I took the nextruder apart and reassembled it, then it started passing again. But even with the load cell working, the Z axis calibration just rams the nozzle into the print bed and keeps trying to force it through. Do I have a bad load cell? Or is something else going on? The printer has been working fine for about 6 months, in fact it just finished a print which worked perfectly, then this problem.
Opublikowany : 25/09/2024 9:08 pm
Chappy69
(@chappy69)
RE: Z Axis Calibration failing
Hi. I'm having this problem now. Did you get a fix?
Opublikowany : 11/05/2025 11:43 am
Grandpa Joe
(@grandpa-joe)
My 4Ks just started this.  I have several indents on my build plate.  Load cell test fails and z test fails when nozzle smashes into build plate.   Any suggestions?
Opublikowany : 17/11/2025 1:43 am
Sara taylor
(@sara-taylor)
It definitely shouldn’t be forcing the nozzle into the plate like that. Even with recalibration, that behavior suggests the load cell isn’t triggering. I’d verify the cables and maybe try a factory reset.
Opublikowany : 27/11/2025 11:26 am
