y axis fails afer FW update
Illusionist
(@illusionist)
not sure if somebody else has the same issue, but since i upgraded to the newest FW my y-axis fails by every test
prints looks fine, dont know what to do ...
anybody the same issue ?
Postato : 03/01/2024 9:00 pm
Russ
 Russ
(@russ-2)
Utenti
RE: y axis fails afer FW update
Had the same issue - it is a known Prusa firmware issue which they are going to fix.  I reinstalled old firmware, completed the tests to allow the printer to work, then updated the firmware but did NOT redo the Y axis test.
Postato : 04/01/2024 12:06 am
miroslav.h4
(@miroslav-h4)
The same problem has been solved here about a hundred times, but there is still someone who is too lazy to look around on the forum to see if someone had the same problem before him and what was the solution. And so a lot of ballast and unnecessary new questions are created over and over again!
Postato : 04/01/2024 9:17 am
Illusionist
(@illusionist)
Thank you very much Russ,- so I will wait for another update and hope I have no bad consequences to expect till then. 🤗
the other: --> a typical miroslav (south europe --> 100km south means a loss of 10 years) , many words without knowledge what i already did....The only waste comes from you. Please do not feel forced to answer anything, because it will not help anybody.
Postato : 04/01/2024 11:36 am
miroslav.h4
(@miroslav-h4)
Illusionist
(@illusionist)
Miroslav, believe it or not, but i went trough all those treads, tried everything, but this has nothing to do with my issue i have.
It is clearly a FW issue, nothing more nothing less
Meanwhile i made a step back to 5.0 🙁
Postato : 04/01/2024 4:34 pm
