xBuddy board schematics
PetervdPerk
(@petervdperk)
Hi I want to make own xBuddy board with different a MCU does anyone know where the schematics are?
Opublikowany : 29/12/2023 12:29 pm
JP Guitars
(@jp-guitars)
RE: xBuddy board schematics
Not sure if it is the right one but there is this
https://github.com/prusa3d/Buddy-board-MINI-PCB
Opublikowany : 29/12/2023 2:27 pm
PetervdPerk
(@petervdperk)
Thanks but I saw those schematics already as well but that's for the buddy from the Prusa Mini.
I'm interested in the xBuddy from the i3 MK4.
Opublikowany : 29/12/2023 2:31 pm
Dudu
 Dudu
(@dudu)
I'm interrested too.
Opublikowany : 08/01/2024 10:13 pm
sudosmudo
(@sudosmudo)
I‘m interested, too.
Is there an update regarding this matter?
Opublikowany : 25/03/2024 10:48 pm
pzad
 pzad
(@pzad)
https://www.prusa3d.com/cs/stranka/open-source-at-prusa-research_236812/
Opublikowany : 26/03/2024 7:01 am
Mr. G
(@mr-g)
Hello y'all,
I have this board with a fried component.
Where can I find the schematics for it? Or if schematics are not available maybe someone can help me identify the smoked part.
Trying to help a friend here fix it. He already purchased the replacement ($119 + S/H), so if I can help him get this board going that would be awesome.
Plus prevent it from getting into a landfill.
Many Thanks in advance,
Mr. G.
closer picture of the fried component:
This post was modified 1 year temu by Mr. G
Opublikowany : 24/11/2024 1:03 am
ssmith
(@ssmith)
The schematics are here.
It looks like you're talking about Q1 in your picture. On the sheet "EXTRUDER" in zones A1-3, outputs from Q1A and Q1B drive fans. The part, SI3993CDV-T1-GE3 , seems to be readily available.
Whatever you find to be the fix, let us know how it comes out. Best of luck!
Opublikowany : 24/11/2024 6:35 pm
Mr. G
(@mr-g)
You are awesome, thank you so much.  I have ordered this part from Mouser. Will definetelly let you know how it worked.
Opublikowany : 24/11/2024 7:17 pm
1 ludzie polubili
Mr. G
(@mr-g)
I replaced the broken part and the board is working like new.  It seems it burned out because the fan grease dried out and stopped spinning. Maybe a PWM signal should be implemented to detect when the fan is not spinning and stop outputting voltage on FAN-0-OUT. But that's a thing for another day.
Thank you all for your help and suggestions.
Mr. G
Opublikowany : 21/04/2026 3:27 pm
2 ludzie polubili
