Wifi - Dash in SSID
ElFroCampeador
(@elfrocampeador)
Wifi - Dash in SSID
After a marathon weekend of upgrading my MK3s to MK4 I had just one issue with setup... wifi wouldn't connect.  After a bit of research, I found a documentation page that says certain special characters, including -, are not supported.
The SSID for my home wifi happens to include a - and I don't feel particularly inclined to reconfigure the wifi on I'm not even sure how many devices just so my printer can connect... Is there a workaround to this weird limitation / Does it seem likely the firmware will be updated to remove it.  I've been rather looking forward to not having to run between rooms to set up prints
Opublikowany : 21/11/2023 6:38 am
jrmcdan
(@jrmcdan)
RE: Wifi - Dash in SSID
Same wifi SSID issue with my MK4 (kit) except the SSID I need to use includes an underscore (_) .
Opublikowany : 26/12/2023 11:22 pm
langer
(@langer)
Same here! Just finished putting it together and finally realized the failed wifi setup is due to our SSID. It has an underscore in the name. Seems like a strange limitation for commonly used characters in network names.
Opublikowany : 27/12/2023 3:38 pm
Eki Honkakoski
(@eki-honkakoski)
I likely have a similar problem with some underscores in WiFi SSD name.
(Everything else has gone really smoothly so far...  I cannot really complain much other than finding a US-power cord in the box (for Finland, EU)...  Luckily there was a spare ones around.    Just unpacked, test calibrated a pre-assembled MK4 and printed out a spatula from usb-drive test part files. Time from printer out from a delivery box to a first quality part took me a like 45mins - 20mins was spent on printing.     I feel I spend more time putting up HP paper printer last week...
Opublikowany : 28/12/2023 8:52 pm
