Thermistor seems ok, but print fails when the temperature changes
mcirmaciu
(@mcirmaciu)
Miembro
Hey,
I have a problem with my MK4. If I start a print, everything is working, but if after some layers the temperature changes to less, let's say from 230 to 220 degrees, the the temperature is not going to stay to this temperature and it keeps dropping and after a while I receive the thermistor error with red screen.
The error says that I need to check the thermistor wiring, I checked this and it's looks ok. If I don't have temperature change instructions in the g-code, the print works.
Este debate ha sido modificado el hace 2 years por mcirmaciu
Respondido : 19/03/2024 10:48 am
