The problem is the Y-belt holder?
pasqua90
(@pasqua90)
Hello everyone, I have a Prusa MK4 since December, and for the past week, the Y-axis belt has been coming loose. I assembled everything correctly and never had any issues, but suddenly the belt loosened. I noticed that the Y-belt holder component is no longer available for purchase on the website. I think there might be a replacement for the part soon. How have you solved the problem?
Opublikowany : 07/07/2024 6:48 pm
RE: The problem is the Y-belt holder?
tell us where you are and someone may be able to help.
or
look for a local makerspace
or
see if your loval library has a printer,
or
https://jlc3dp.com/3d-printing-quote
Opublikowany : 07/07/2024 9:57 pm
poundCake
(@poundcake)
Posted by: @pasqua90
Same issue, mk3.9 build with Prusa PETG and the Y belt holder has lost functionality.  Pathetic.  The old design was superior but won't pass calibration with the new software.
Opublikowany : 30/07/2024 4:21 am
JamesHejmanowski
(@jameshejmanowski)
I struggled with that problem a lot - I could print once or twice and then the belt would pop out of the belt holder no matter what I did. I tried several of the y-belt mods on Printables.com and these two together completely solved the problem and tensioning the belt is both reliable and much easier than the original parts form Prusa. Try this - you will like it!
https://www.printables.com/model/149658-y-axis-belt
https://www.printables.com/model/727247-y-belt-holder-one-piece-mod-for-mk4
Opublikowany : 05/08/2024 10:33 pm
