[Solved] Sock installed menu option
Davebert
(@davebert)
I just installed the latest v6 firmware and while I was at it I installed a sock on the hot end. I had read somewhere here on the forum about making sure to select you had a sock installed but don't know if that is in the firmware or in the slicer. Where do I choose yes or no that I have a sock installed?
Thanks
Best Answer by Davebert:
Found it:
Once the silicone sock is installed on the MK4 or MK3. 9, the printer needs to be adjusted. Navigate to LCD Menu -> Settings -> Hardware -> Nextruder Silicone sock, and set it to ON. This step is not performed on the XL.
This topic was modified před 2 years by Davebert
Napsal : 21/04/2024 12:51 pm
Davebert
(@davebert)
RE: Sock installed menu option
Found it:
Napsal : 21/04/2024 12:59 pm
