Send to printer - HTTP 404 error
Anders Mac
(@anders-mac)
Mitglied
Every time I send a print job from slicer with PrusaLink to our MK4 I get this error message. But there is no real error, the prints starts just fine. I have several MK3S with OctoPrint and they do not have the same problem.
Is there a way to fix this..?
Dieses Thema wurde geändert Vor 2 years von Anders Mac
Veröffentlicht : 23/04/2024 11:14 am
JP Guitars
(@jp-guitars)
RE: Send to printer - HTTP 404 error
The clue is in the error message, slicer cannot find the printer. What has probably happened is your DHCP servers has allocated a new ip address but you are still sending to the old one, so check the ip address on the slicer and printer are the same
Veröffentlicht : 23/04/2024 2:40 pm
Frank
(@frank-21)
Mitglied
Maybe the same connection problems I have? What firmware version are you using and what connection type? Lan or WLan ?
Veröffentlicht : 23/04/2024 7:15 pm
Anders Mac
(@anders-mac)
Mitglied
Nope, that is not it. It has a set IP address and it works perfectly fine when i click the test connection button in Slicer. And the print is sent to the printer and starts printing, the problem is the false alarm error message.
Posted by: @jp-guitars
Veröffentlicht : 24/04/2024 1:14 pm
Anders Mac
(@anders-mac)
Mitglied
Good question, I did not update firmware efter getting it. LAN.
Posted by: @frank-23
Veröffentlicht : 24/04/2024 1:15 pm
CyclonEngr
(@cyclonengr)
Not sure if you got it fixed.  I had the same error message and discovered that the API key was 'wrong' . . .   You probably are using the correct "key" or password for the type of connection, but that was also a problem I discovered.
GOOD LUCK
Veröffentlicht : 01/05/2024 12:55 am
Anders Mac
(@anders-mac)
Mitglied
I searched and found this thread...
Posted by: @tojik
We know about the error. It's not been easy to hunt down tho. I've seen some fixes being attempted but I am not sure if a fix is in an upcoming FW update or not.
 Wtf seriously, how can this possible be a difficult problem to fix?
Veröffentlicht : 02/05/2024 8:23 am
kroneyd
(@kroneyd)
I had the same error.  I ended up resetting my printer - which in retrospect may not have been necessary.  In the course of needing to copy the firmware to the USB to reload I discovered that the USB may have been corrupted.  I reformatted the USB, loaded the firmware and reconfigured the printer.  Seems to be working now.  If I encounter the problem again - I would first check the USB to see if it is corrupted before resetting the printer.
Veröffentlicht : 29/06/2025 9:20 pm
