rubber sheet spare parts
ManelTo
(@manelto)
I like to have spares for all the parts that can, after breaking down, make the printer unusable. In the assembly of the kit, where the linear bearing has to be placed, small rubber plates are placed to better fix these components. Do you know where to get them?I have seen on Amazon some 25mm x 1.5mm rolls that, after cutting them to the correct size, could work if not because the thickness is 0.5mm greater than the original ones.
Sorry for my poor English. I try to do my best.
Respondido : 11/08/2023 6:45 pm
w huson
(@w-huson)
RE: rubber sheet spare parts
Hello
User Hacko has published the following:
https://www.printables.com/model/514039-mk4-rubber-parts
and
https://www.printables.com/model/515973-mk4-y-plastic-bearing-pad
So, you can print them yourself.
Regards, Willem
Respondido : 11/08/2023 6:53 pm
1 les gusta
sarahbellum
(@sarahbellum)
Miembro
Ebay has a seller in UK who sells 1mm thick rubber pads: https://www.ebay.com/itm/Black-Rubber-Sheet-1mm-Thick-3-Sizes-Available-/262591579269
Respondido : 12/01/2024 11:20 pm
asp ds
(@asp-ds)
Miembro
What's the exact thickness, you are looking for..
rubber technologist
Respondido : 11/07/2025 7:43 pm
