PrusaSlicer MK4 Presets?
TwoBallScrewBall
(@twoballscrewball)
Do we know when Prusaslicer will be updated with the presets for the MK4?  Ordered mine today 🙂
Respondido : 29/03/2023 8:18 pm
RE: PrusaSlicer MK4 Presets?
twitter says prusa slicer 2.5.2 will be out 30 march 2023, with Mk4 profiles, And the 2.6.0 alpha 5 will get the profiles at the same time
https://twitter.com/PrusaSlicer/status/1641158628563464192
Respondido : 29/03/2023 11:13 pm
4 les gusta
TwoBallScrewBall
(@twoballscrewball)
Thank you! I don't have Twitter so I didn't see that. I very much appreciate it. Can't wait to try this new MK4.
Respondido : 29/03/2023 11:58 pm
jas
 jas
(@jas)
You can always follow the github page if you want updates
https://github.com/prusa3d/PrusaSlicer
it will always, 100% of the time be the first place where updates will get posted.
Posted by: @twoballscrewball
Respondido : 30/03/2023 1:32 am
1 les gusta
TwoBallScrewBall
(@twoballscrewball)
That's more my speed, thanks 🙂
Respondido : 30/03/2023 3:40 am
1 les gusta
Doriann
(@doriann)
In the 2.6 alpha 5 you can select it also now.
Respondido : 01/04/2023 1:30 am
TinyWorkshop
(@tinyworkshop-2)
are the preset in the last build of prusalicer accurate?
the times of the MK4 are a bit disappointing compared to the MK3, TBH....
Respondido : 03/04/2023 3:25 pm
Doriann
(@doriann)
Posted by: @tinyworkshop-2
Basked on Tom's last video they should be. They are not X1C speeds but that will come in a later firmware update
Respondido : 03/04/2023 3:33 pm
TwoBallScrewBall
(@twoballscrewball)
Thinking the same thing, I have a custom .25mm profile I use a lot on my MK3S+ printers, a particular part takes 50m to print using this profile.   I pulled up the standard MK4 .20mm profile, and just upped the layer height to .25mm, and the slicer actually says it will take longer to print on the MK4 vs. the MK3S+ (53m up from 50m) so I'm pretty confused, as I was excited to cut my print times down.....
Respondido : 03/04/2023 3:42 pm
Shushuda
(@shushuda)
"Since it’s all still under development, it also means that Input Shaper and Pressure Advance won’t be available in the shipping firmware. But I’m sure you’re eager to try it as soon as possible, so we will probably soon release an alpha firmware with input shaping and Pressure Advance in a few weeks. It won’t be as feature-packed as the full firmware, but you can play around with it until we merge the two branches."
https://blog.prusa3d.com/announcing-original-prusa-mk4_76585/
Jo mentioned they want to release that alpha in about a month in Thomas' video -
Respondido : 03/04/2023 3:56 pm
addohm
(@addohm)
We're on Alpha-6.  Just sayin 😀
Posted by: @doriann
Respondido : 03/04/2023 9:45 pm
TinyWorkshop
(@tinyworkshop-2)
I really hope so 😆
at least with the upgrade kit I have time to evaluate the situation (since seems we are the last in the cue of the orders)
I have mainly bought the upgrade kit for the "up to 70% reduction in time"
Posted by: @shushuda
Respondido : 04/04/2023 5:02 am
DarteKO
(@darteko)
Prusa Slicer MK3S+ & MK4 estimated printing time... Possible? Or just a miscalculation?
Esta publicación ha sido modificada el hace 3 years 2 veces por DarteKO
Respondido : 07/04/2023 8:39 pm
jkavalik
(@jkavalik)
Miembro
The difference seems to be almost exclusively in the infill, both solid and sparse - can you compare that both visually and in presets?
Posted by: @darteko
Respondido : 08/04/2023 7:50 am
DarteKO
(@darteko)
All settings are the same,only the printer version MK3S+ and MK4.
Posted by: @jkavalik
Posted by: @darteko
Respondido : 08/04/2023 10:04 am
