PrusaLink: Won't accept credentials
Bill
 Bill
(@bill-2)
I'm trying to set up PrusaLink on my new MK4.
I have connected with an Ethernet cable.
I can get to the PrusaLink web page on the printer.
But, I can't log in. When I type in the username and password, the dialog box just comes back for me to log in again.
I WebChatted with Prusa support, who suggested the following ideas, none of which worked:
  • I've tried regenerating passwords.
  • I'm copy/pasting them from a text window, so I know I haven't mis-typed them.
  • I've factory reset the printer.
Anybody have any other ideas?  I'm seeing the webpage, so I know most of the potential networking problems aren't an issue.
Best Answer by Koegmaster:
Are you by any chance using Safari as you Browser?
I am facing exactly the same issue in Safari, but when I switch to Chrome everything works as expected. So I am just using Chrome as a Workaround for now, but hope this issue can be fixed in future.
Hope that helps!
Napsal : 22/04/2023 2:14 am
1 lidem se líbí
Koegmaster
(@koegmaster)
RE: PrusaLink: Won't accept credentials
Hope that helps!
Napsal : 23/04/2023 6:23 pm
Bill
 Bill
(@bill-2)
You've got to be kidding me, Prusa!
Thanks so much, Koegmaster.  Chrome is working.  Safari is not.  Good thing I didn't have to fire up Internet Explorer....
Napsal : 24/04/2023 1:10 am
iftibashir
(@iftibashir)
Does this also affect Safari on iPhones and iPads as well as on a Mac?
Napsal : 24/04/2023 10:56 am
Bill
 Bill
(@bill-2)
Unfortunately, it looks like it.  My iPhone can't connect.
Napsal : 24/04/2023 11:24 am
I see the same with a Prusa XL. Chromes works fine, Safari doesn't.
Napsal : 24/04/2023 1:02 pm
Dean
 Dean
(@dean-2)
I immediately assumed this might be a 'Safari as a second class citizen' issue and tried Chrome. But Chrome doesn't work for me either. Anyone else?
Napsal : 24/04/2023 2:57 pm
Dean
 Dean
(@dean-2)
It was my error with Chrome. Also, the issue is an open issue on GitHub and the issue poster noted it eventually works, which I can confirm.
Napsal : 24/04/2023 5:27 pm
ingorichter
(@ingorichter)
I use Vivaldi (which is based on Chrome) and it doesn't work for me either
Napsal : 27/05/2023 5:23 pm
BootStrap
(@bootstrap)
Does not work with Chrome or Safari..
Tried generating credentials again.. Same issue.
Napsal : 30/06/2023 3:40 pm
jstm88
(@jstm88)
Bumping this topic since 5.1.0 still has the same problem.
This should be a simple fix... since, you know, about 99.9999% of the internet gets it right. 🤣
Napsal : 28/11/2023 4:23 pm
Sentuary
(@sentuary)
I have the same issue on the mini+ with firefox and edge
Napsal : 12/01/2024 2:56 pm
